ambient light sensor
pilifida
Hello guys, i checked in the service menu the value of this sensor.
the weird part is that this sensor has just 2 values: 0 and 6645.
when you cover it up it.s 0, when it;s free is 6645.
This is really weird as the value should increase/decrease gradually when you move your finger over it.
There were reported problems of lower battery time using ambient light on. So, can you please check if your sensor is showing normal values? (more than 2)
also i tried 2 ambient light sensor apps that work well on another phone and they say they can't detect the sensor...
Thank you!
7 REPLIES 7
profile.country.AT.title
skycamefalling
You might have mistaken the ambient light sensor for the proximity sensor.
The ambient light sensor has several values which can be easily seen in the Support --> Tests menu where the picture is gradually changing it's visibility.
Either that or the values the apps can read are wrong. How are you reading the sensor output?
pilifida
no, i'm not mistaking it. i see it in *#*#service#*#* the old service menu.
i see now it's included. But i comparez the sensors with an xz premium and z2 and, trust me, i'm not confusing any sensor.
I tried again today and seems to work, not quite good but okeish.
Also if i'm leaving it on, the display it's not that resposive in terms of changing the "light", i prefer it turned off. wonder if it's a software or a hardware problem
pilifida
now, reading here on forum, i ticked on ambient display always on. Guess what? no ambient display whatsoever, no appearing on lifting etc. weird...
skycamefalling
Okay, I've tried with the service-menu through the phone-app, as you did.
The value for my ambient light sensor ranges between 0 and 325,83 indoors with many, many gradients in between depending on where the sensor is facing.
Also, my ambient display works as it should.
Seem like a soft- or hardware-problem with your phone. Software repair might help...
pilifida
thank you! can you post a photo of how ambient display should look like? i guess it;s a clock on a black screen, but i have'n seent it ever since i was not interested in it, i didn't played with this feature. Now playing with the settings, conducted me to the conclusion that this isn;t working for me, lol ::))
skycamefalling
Oh great, so you've found the culprit for the Ambient Display.
Doesn't explain why your ambient light sensor readings are off, though...
pilifida
it's not quite of, for example, today it somehow worked. the funny stuff it sometimes varies the value depending on how i tilt the phone. i got 0, for example, then i lightly tilt the phoe (2-3 degrees) and then ai got that 6000 value. anyway, i prefer it off as i read that it consumes more power when it's on. But i thought that maybe it's a correlation between its high battery usage and this weird behaviour...
i tried it in the test menu and it slightly worked okeish.
