Airpods with xperia xz premium issues
Mohgh32
I connected a airpods to my xperia xz premium and everything works fine i can use sensor touch to pause and play but i can't answer the call using sensor touch.
When i double touches on sensors Bluetooth disconnects
Any idea to fix this issue
Yes of cause this airpods are from apple
2 REPLIES 2
@Mohgh32
you have answer your own question, you can use them to listen to music but won't work for everything they were meant to; there's nothing wrong with your phone nor the airpods.
Mohgh32
No bro there is a problem in xperia because i just brought a new promate trueblue earbud same results i lost  29kwd and checked to Samsung gear icon same result and chacked to sony wf-1000x same result can't pick up the call using sensor
