Z5 premium - fingerprint scanner issues
profile.country.en_GB.title
dweaver1
Member
With my first fingerprint this only unlocked the phone about 25% of the time - awful...
So I re-scanned my fingerprints & it now works about 50% of the time (not sure what has changed though...).
Better - but still fails half the time (not exactly impressive).
Please Sony fix this...
28 REPLIES 28
profile.country.DK.title
jchristensen
New
Hello.
I have the same problem, Z5 Compact.
I THINK I have the solution:
I have registred 5 of my fingers and sometimes no of the fingers can unlock.
Sometimes I can unlock and sometimes I must use my code, cause no of my fingers are known by the scanner.
Mostly we got told that our fingers are wet or the scanne is wet or scratched.
Though, I am quite sure that it is the weather. Your fingers are getting too dry!
My fingers are really dry to day and I can't unlock without the code.
I will advice against deleting your fingerprints beacause you can't register your fingers if they are dry.
profile.country.RO.title
_alexdon_
@Dean_Weaver
Keep us updated.
@jchris1953
Thanks, I don't have the Z5 yet but it is useful information for others.
alexdon
Sidler1
My Z5 is also finicky with fingerprint scanner, but it is just my sweaty hands. Wipe them off and it works much better. I really like this when it works, but don't often have a cotton shirt on to absorb all the sweat. The tip of my thumb seems to work best as it is driest.
I really like having multiple fingers profiled as I often grab it with my left hand. I have left index, middle and right thumb and it's covered every time I pick it up - As long as my hands aren't damp.
dweaver1
Member
These are the results of my tests:
On the day my fingerprints were registered, I used the scanner 100 times & my success rate was 80%
On the first day after registering I repeated this, but it had fallen to 73%
On the second day, this had fallen to 65%
By the third day, this was only 42%
I then cleaned the sensor (with a ‘baby wipe’), repeated the test & got 55% - not even as-good as it was yesterday…..
At this point I find the failure rate very annoying - I have disabled this ‘feature’.......
When I buy a ‘premium’ product, I expect a premium price, but expect premium performance. What I actually get is useless & expensive rubbish - thanks Sony - this is a (very bad) joke…..
This is terrible - this is my last Sony phone.
So my question is WHY IS THIS CHANGING ?
_alexdon_
@Dean_Weaver Can you let someone else set up the fingerprints and see if the same problems occur?
alexdon
NeoBeum
Enthusiast
NeoBeum
Enthusiast
dont do this, register 2 ,
and register them more than once...
I did Middle, next verify with middle, index, next verify with index, thumb, back to index back to middle
my scanner on the compact unlocks me everytime.
also, if you register the same finger using the technique i posted above, you'll almost guaranteed 100% of the time to unlock, if you register that finger 5 times, upsidedown, sideways, normal, pressing really hard, and then another normal sweep
EDIT: imma do another paint job (because i can, and because i'm bored) with another visual example that might help some people with how the scanner sort of picks up the print brb
NeoBeum
Enthusiast
That's just a visual representation...
edit: also because we're working in measurements smaller than a millimetre, everyone will have a different tactile/touch feedback , --so, if you press too hard, it's enough pressure to distort your fingerprint enough, where the scanner picks up the ridges and groves to cause a mismatch. so it helps if you scan the same finger on another register, using different pressures when you activate the scanner, so it has more samples to reduce the errors in reading
Xperianyi
NeoBeum, thanks for the tip. But I'm a bit confused here.
So is it good idea to register one finger multiple times, or bad?
dweaver1
Member
Alexdon - the response from 'sonymobile' was to perform a repair with PC Companion (as you suggested..). So after performing a backup, this is what I did. Just registered my fingerprints & with 100 attempts at unlocking, I had 95 successful (marvellous) - but will it last....
I will report in a few days.
