Hey guys.
I live in Sweden where the z4 tab has been in stores for some time now and I like the z4 very much but.... I'm having some WiFi problems. I get connection errors and slow response time and poor speed. Anyone else that's experiencing the same thing or is tab broken?
The battery time is not that impressive, but I'm only on my second cycle so maybe it will improve.
Best regards
Daniel
What if you reinstall the latest update with PCC, it might smooth things out
Bridge (for Mac)
Hello uliwooly! Thanks for helping out.
Is that a known problem that updates doesn't work properly on Sony devices? (first Sony device for me)
Update: I tried static ip as the troubleshooting guide suggested and the difference was huge!
No connection drops or low speeds this far. Hope that it continues this way!
I have an Asus (5GHz) router for future reference.
Same here, poor WiFi and battery on my Swedish tablet.
Im starting to have a problem where the WIFI keeps dropping out, no other device in the house is having trouble so it has to be the Z4.
Its getting frustrating, Its got the latest update installed and not being a techno wizzard any help and advive would be appreciated
I returned mine due 2 unstable wifi connection
Ill post once i i hear from the dealer again
Unacceptable from a tablet with that price tag
Seems the Z4 needs a new firmware since it wasnt 100% working with comhem`s compal CH7486e router,
had 2 use my even older Asus router in "AP" mode (cable betwwen the 2 routers)
/sweden
I'm having the same problem. Have changed to static ip in my router but no change. All my other devices are functioning at 100%. Will try a software repair, if that won't work I'm selling this piece of crap and getting an iPad. The Sony support was not much help. Their solution was to uninstall one app at a time to see which one is the problem. With over 100 apps solve the issue Sony! We're are many having the same problem.
So I just made a software repair using companion. DIDN'T HELP A BIT! So far has not one suggested fix from Sony helped. They need to address this issue. Educate their supportstaff, test their hardware/software and develop a fix for this issue asap. I'm really dissappointed at Sony so far.
At home I'm not using a cover for the Z4.
I recognize that the tablet has issues with WiFi connection when I lay it flat on a wooden table at home. As soon as I hold it upright or put it upright into the keyboard the connection is good. This applies to both 2.4GHz and 5GHz. On a glass table at home I don't have this issue.
Maybe the problem lays in the flat design of the tablet. When the attenna is close to a slow conductive medium like the wooden table the signal gets a bad coupling.
Another thing I recognized: nowadays in 2.4 GHz there are more than 12 other WiFi SSIDs in close range, visible in the Z4. Maybe this is also bringing the connection down. On the 5 GHz I'm the only one in proximity. But the connectivity through more than one wall is horrible on 5 GHz. Not sure if this only a problem of my Z4. With my mobile phone (non-Sony) I have in some rooms good connection on 5GHz, in others not. But with Z4 I have to be more or less in visible range to the router when using 5 GHz.
