I have a problem with the top speaker strays
you must have java to sony pc companion
So I've been told yes you do need it
why is designated as the system requirements across
No idea - Ask Xperia care but most programs that flash devices require Java as the code is often Java based and as such requires it to run http://www.sonymobile.com/global-en/support/contact-us/
Mobile after coming off the water less than 10 centimeter sound very low
It's possible you have water around the speaker grill still which may cause this
Stop posting multiple threads on the same topic, it's normal, you have to wait for the speaker to dry out
