Hi Fimb
Welcome to the community.
I would suggest checking to see if this is a potential hardware problem. To use Xperia Diagnostics
Go to Settings > About phone > Diagnostics.
Tap Test device.
Select the Charging
Follow the on-screen instructions.
Could you let us know what the results of that are?
If it fails the test have a chat with your contact your Local support team as it will need to be serviced.
