z3 compact vibrate not working
jezboy007
Explorer
Right had this z3 for less than a month and the vibrate has stopped working, I've been in to diagnostics and the hidden service menu and nothing can getting working and yes I've been in to the text menu and ticked all the boxes and restarted the device! Now I paid £400 for this device to replace a faulty z1 compact that had been back to sbe to be repaired and always came back with a different problem! Frankly if this one is faulty to I'm not prepared to take a repair it will have to be a new device
4 REPLIES 4
jezboy007
Explorer
OK vibrate randomly started again and then stopped?
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
rich_ni
Jez2110 I also have a device that is suffering from the same symptoms - did the factory reset work or was it a hardware issue in the end?  Reluctant to go through the headache of a factory reset if it is unlikely to do anything to help.
I'd be greatful to know how this issue was resolved for you?
Thanks
Rich.
Sam
Legend
Legend
@rich_ni - The difficulty is that there can be a nubmer of reasons for this to happen so whilst the steps above may not resolve some causes it will resolve others. With this said it is worth trying as the other option is to speak with your local Xperia Care team regarding having a repair arranged.
