z3 compact not receiving calls
GregRE
Hi Guys & Gals
Over the last 2 days my phone when recieving calls and i slide the slider the screen goes blank, the caller can hear me but i cannot hear them nor can i access the screen untill the caller hanges up. i have checked on fourms and followed the advice, and also i have done a factory reset and was onto sont chat today and they told me to install pc companion 2.02.015 and run the uipdate which i have done and still having the same problem.
Any help would be much appreciated.
Thanks Guys & Gals
Greg
9 REPLIES 9
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
GregRE
Hi Thommo, thanks for the reply, but I have already tried this as I said in my post. It didn't make any difference.. Any other suggestions!!
Thommo
Genius
A factory reset is not the same as a system repair
GregRE
Yep I know that, that's why I'm my post it said I done both 🙂 any other taughts!! And thanks again Thommo.
Thommo
Genius
I read your post and saw no mention of a system repair only a system update and factory reset however if this still happens then you can test in safemode and if it still happens then I'm sorry to hear this but you would need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
GregRE
I have tried all of the above and also ran it in safe mode and the issue is still the same.
lukdra
I have the same problem. Before update everything was ok but after update i have problem with call - the caller cant hear me. I need fast fix that, maybe in next update.
MrZoule
I can see that when I accept the call, the conversation is immediatly closed, and the phone display the star icon in top notifications, which is about allowing interruptions or not.
Maybe there is a bug at this level : the call is rejected because the phone auto-active interruption mode... ???
Do you have the same ?
MrZoule
Resolved : I had an application (bouygtel) to block anonymous calls. It was obviously no compatible with android 5.
