Z3 compact lag
betrue2yourself
Z3 compact lag
HI there!
So, I bought the gadget few weeks ago in December. Everything was ok till yesterday.
The phone started to lag. Antutu benchmark has shown 37-38k instead of usual 45-46k. While performing video tests - very hard lags and the downfall of fps from usual 40 to 27-28.
The lag dissapears when connected to the charger. Already tried to hard reset/to work in Safe Mode - nothing helped. What is the issue can be?
Thanks in advance!
12 REPLIES 12
profile.country.RO.title
_alexdon_
Do you have stamina mode enabled?
alexdon
betrue2yourself
No, I do not use it at all.
_alexdon_
Could you perform a software repair? Safe mode should help in your case but I see it doesn't.
alexdon
betrue2yourself
You mean usual Reset to Factory Settings? Now performing. Hope that helps but do not think so. Will let you know shortly about the results.
betrue2yourself
Did not help...
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
betrue2yourself
Thx. Gonna try now. Will let you know shortly.
_alexdon_
Keep us updated.
alexdon
betrue2yourself
After a hard reboot of Z3 Compact the laptop cannot find the phone - the same for PC companion....?!
Win7 Enterprise 64bit
Charging but nothing else...Although few days ago I had no robelms with connecting it to the same laptop (which is Sony Vaio btw)
