my Z3 Compact has been updated last week to Android 5.1.1 Build #23.4.A.1.200
Since the updated I have the following issues:
1) The double tap to wake up seems to not work consistently. I have noticed that if I manually turn off the screen (by lightly pressing the power button) then it will not wake up on double tap. If I allow the phone to shut down the screen automatically at the preset time, then sometimes the doulbe tap to wak the screen works. I stress, sometimes! It's random.
2) Additionally, ever since the update, the three on screen buttons, the "Back" button, the "Home" button and the "Recents" button freeze. I will tap many times on them without any result. There are times when all of them are frozen, and times when either 1 or 2 are frozen. The issue is random, and it's not app dependent. I say this because it can happen even immediately after ulocking the screen, or if I flip to any pages on the home screen.
Please help.
If a solution is not readily available, is there a way to revert to the previous built?
I did not have these problems prior to the update last week.
Thanks.
Have you tried a software repair?
Perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
