Z2 wont come on
phonebattery
Z2 wont come on
Has anybody else had a problem with there z2 with it not charging or.power on? I have the contract with Virgin media and then said it's not under warranty. The phone was great when it worked but I don't no how to fix it it's had a new charging port fitted and been on charge for a long time bit still comes.up when you try power on with the flat battery picture.
Thanks
She
Tags (1)
3 REPLIES 3
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
phonebattery
I can't do that as the phone won't even charge slightly
I have tried everything.
_alexdon_
In this case,try to contact your local sony team:
alexdon
