Z2 Problems
Alex2003
Z2 Problems
Hi Sony,
I just want to share my problems on my Xperia Z2.
First is the sd card error message always pops up "unexpected removal of sd card".
Second is when Im using the SBH52 headset for text to speech like for email and facebook notifications, the volume is always at low when starts to speech. Even I increased the volume it will go back to low volume when starts to read again.
Please help to solve this issue. Your xperia Z2 design great and I love it.
Thank you and regards,
Alex
7 REPLIES 7
HussainQuadri
@Alex2003 wrote:
Hi Sony,
Alex
I suggest you try an reinsert the micro SD card to make sure it goes in properly.
dandy63
Leader
Rgards the Unexpected Sd Card message....do you just take out the card as you are meant to go into SETTINGS...STORAGE....then scroll down to see the UNMOUNT SD CARD option...
Cheers
Alex2003
Thanks for the advice but still same problem.
By the way I'm using sandisk 64gb.
dandy63
Leader
If you have a different SD card try unmounting the 64gb one and see if the same message pops up with the temp one.....narrows down the potential culprit to either SD card or phone
evildrag
any fix to the sbh52 tts too low volumen when sms ?
Utpal_Goswami
I am also having this problem with my Z3 & SBH52, and i guess I have found a solution for this,
When it starts playing - if you  just press volume down 'once' on the SBH52, it increases the volume to 70-80% and then you can change volume as you want.
Pls try it, I think it is working every 5 times out of 7, its still a bug but atleast this will make you less irritated.
uyAlex
Still same problem. Nothing I can do with this volume. i think the version of google text to speech version is the problem 🙂
