I've had my Xperia Z2 for about a month, three days ago the camera wouldn't start. When I open the app the screen is black. It's also the same if I try to start the camera using Instagram or Snapchat. I've tried to restart the unit and cacheclan phone to see if storage was the problem. I`ve also tried to connect to the "update service" but when I hold the "volume down button" and connect the usb I get a message that the program can't find the unit. Starting to be a bit frustrated. I'ts just problem with the front/main camera, not the small one. Anyone having this problem?
A software update would be the best option to at least rule out a software issue. However when you have tried to run this, have you tried using another USB port and are you using PC Companion or the Update Service?
Hi
I have tried to use another USB port, same message: can't find the device (Update Service). Have also got the latest updates from PC Companion. For information: The camera starts/open, but the screen is black. All the symbols, like the camera recorder button for example are still visible at the screen. But the don't work when I push them.
hold power button and volume up together and wait for device to vibrate 3 times , then restart device after 12 seconds and try again .
It did'nt work either
Hi Ajay28 and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Please try this: Main Menu > Settings > Apps > All > Camera > Clear data.
grrrr!!!! same problem 3 days old z2 phone and my camera wont work..... huhuhu z2 is so expensive then ganyan..
