Z2 Bluetooth audio problem
Hello Slightly_smiling_Face I bought recently sony xb950bt headphones and I have a problem... When I play music over Bluetooth there is a very annoying background hiss/noise , when I pause song it stops after 2,3 seconds.. It happens in every app, YouTube, Walkman, etc... I tried headphones whit two other phones and ther is no such problem ... When I play music with cable everything is OK... Can anyone help me with this problem? Thanks
8 REPLIES 8
Phy
Legend
Legend
Do you experience the same noise while on safe mode?
How to boot on safe mode
How to boot on safe mode on Lolipop
1. press and hold the power key
2. once you get the pop up menu
3. press and hold "power off"
4. Boot on safe mode should become available
Yes, problem is still here... I tried on galaxy s3 too there is a same noise..but on my old Nokia 5310 works perfectly
SophiaW
Enthusiast
That is quite strange Marioz1990, try clearing the data for Smart Connect and test out the headphones again. If the problem persists, what I advise is running a software repair on the handset as that is likely to resolve the issue by removing & re-installing the operating system. If running a software repair doesn't work I would then advise getting the phone into your local authorized Sony repairer to have it assessed for you.
Note: a software repair will delete all user data, to back up your phone using PC Companion
1. Go to Support to install PC Companion on a Windows computer.
2. When installed, start PC Companion on the computer.
3. Connect your phone to the computer using a USB cable.
4. Click Start under Backup & Restore.
5. Follow the on-screen instructions.
(Exactly what contents will be backed up may differ depending on phone model.
You can view detailed information about this as you follow the steps in the Backup & Restore wizard).
Running the software repair on PC Companion:
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
Keep us updated, I do hope this resolves the issue for you.
Thanks for reply... I will try with software repair tomorrow.. I am thinking more and more that I have a faulty headset (background hiss on z2 and s3) but on the other side works perfect on my old Nokia... I will try with software repair, and if that doesn't help I don't know what to do next
SophiaW
Enthusiast
I see, to clear the data of Smart Connect go into Settings > Apps > All > scroll down and tap on SmartConnect > tap Clear data > test the headphones again. You can also try different Audio settings under Settings > Sound & notification. If the problem is experienced on other handsets it would seem it is the headset yes. It is up to you whether you would like to try the software repair, running the repair will rule out any software problems with the phone. Try other headsets with your Xperia Z2 & if the issue does not occur with other headsets then it is most likely those xb950bt headphones. Contact your local Sony Xperia Customer Care team to arrange having the headset assessed if that is the case.
I repaired the software but nothing changes, on laptop too i have the same problem so i think headphones are defected... Im sending them back for replacement, and i Will update this tread if i encounter problems with New earphones...
So the New headphones arrived, i tried them but the problem persist...on galaxy s3,Sony z2 and laptop there is an problem,hiss in the backround, , on old nokia 5310 works perfektly .. I really dont know what to do Slightly_frowning_Face
Phy
Legend
Legend
Contact Sony Xperia support perhaps they can evaluate the problem.
