z1 screen not displaying
vinnu
I had taken mobile 3 days ago..But now i am facing problems that is screen is not displaying but phone is working. What is the reason for it.
4 REPLIES 4
Jake-SonyXperia
Hi vinnu,
This may be related to a software based issue, I first suggest that you hold down the Power Key and Volume Down key together and restart the handset.
If this has not affect then I can only suggest that you try performing a software repair on the handset, this can be done by doing the following
PC Companion
To repair the phone software
1.     Install PC Companion on a Windows PC from Support
2.     In PC Companion, under Support Zone and click Start.
3.     Under Phone Software Update, click Start.
4.     Click repair phone.
5.     Follow the on-screen instructions.
I apologize for any inconvenience this may cause.
What are your thoughts about this forum? Let us know by doing this short survey.
vinnu
The mobile gets turned off and it did not get restarting....
Jake-SonyXperia
Did you try performing the task above?
vinnu
its fine ... Thank you jake
