My screen just turns black when i was swapping back to front camera... and phone works but screen is dead i tried every solution with button holding phone is in good condition it never fall down... when i hold buttons i feel wibrations and light above the screen blinks like when tel works normally and i dont know what to do now please help
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data
If that fails then you need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
Hi belfegor1991pl,
You could also try clearing the data fro Camera and Cameras within the apps section.
Menu > Settings > Apps > All > Camera and Cameras > Clear Data.
Try using it, if this does not help try Alexdons instructions, however failing this, you may need to get the device to a service agent.
