Z1 Compact making an alert sound while charging
NCW1978
Hi
Just got the Z1 compact and really like it but when a charge it I get a very annoying alert sound through the speakers usually when I connect it and when it is nearly fully charged.
I does not happen in silent mode but I do not want to activate this through the night incase I get a call from work.
Anyone else had the same problem?
Thanks
Nathan
6 REPLIES 6
Jake-SonyXperia
Hi NCW1978,
With the information provided, can you please advise if you get a pop up box on the screen as well to advise of charge?
Sorry for the inconvenience this may cause.
What are your thoughts about this forum? Let us know by doing this short survey.
kind3r
Perhaps it's the waterproofing warning popup ?
morat
My wife's z1 compact does this, mine doesn't. There is no pop up, and I can't find a relevant setting. It is infuriating.
Sam
Legend
Legend
Hi morat and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
On your wife's phone please try this: Main Menu > Settings > Apps > SmartConnect > Clear Data.
Please let us know if this solves the issue for you.
morat
Thanks for the reply, I did try your suggestion but no joy Slightly_frowning_Face
I have taken a video of it and stuck it on YouTube. Here Z1 compact charging fault: http://youtu.be/I4TujnCxbDs
MBA
Mine is ~ a month old and just over the last week started this same behavior.
I tried the suggestion of clearing data in the Smart Connect app.
Also reloaded the device to factory default using the Sony PC Companion software last evening; no luck.
Same time as this issue started, it also started exhibiting charging & shut down problems.
After charging all night I can’t wake it up; need to restart using the power and volume up buttons until it vibrates 3x.
I’m going to be calling Sony this morning and hope they just replace it… seems like a hardware issue to me.
