Z1 4.4.2 Volume Issue using SBH52 Bluetooth Headset
FocUS2K
Hello All,  I just recently updated to 4.4.2 Firmware and have run into a sorta problem.  After the update you can no longer change the volume of the SBH52 Headset independently of the phone volume. If you raise or lower the volume on the headset it does it on the phone also. This is a problem when using more than one bluetooth device. When I connect to the car the volume is low, and when I go back to the headset the volume is loud because I have to raise it for the car. Prior to the update, the volume was the same on the phone no matter what bluetooth device you were using.  If there are any soultions to this please let me know. Thank you.
FocUS2K
Bump
