XperiaP TV output via HDMI cable
ARafael
When I tried to connect my Xperia P LT22i phone to my TV through the HDMI cable that comes with the phone, the picture quality is good enough.
But sometimes the image is quickly distorted (1 time per about 20 seconds). The TV is Samsung LN37A450 (not full HD).
The problem is independent from applications which running.
I have checked this cable with another device and it works fine, without this problem.
Do anyone have suggestions?
3 REPLIES 3
Jake-SonyXperia
Does the picture come back to normal after a period of time? as this is generally related to load times and memory use, so every so often it will take a few seconds to load the image correctly.
ARafael
It looks like a problem with synchronization. The picture quickly blinks (< 1 sec) and then looks normal.
I am bothered this periodical blinking.
ARafael
I have checked this stuff with other TV (Sony brand) and it works fine! It seems this is compatibility problem!
Thanks to all for attention.
