Xperia ZR Help.
Karan_Yaduvansh
Xperia ZR Help.
I Got this Phone 2 Days Ago And I Am Loving It But I Want To Ask Some Question Regarding It Please Make Them Clear:-
1. Is Xperia Zr Also Uses Dragontail Glass(or Gorilla Glass)?
2. When I Clicked Photos Some Of Them Are Shaky(Blury)
3. X4 player Lags Many Times It's Stucked.
4. Battery Draining When I Leave my Phone In Standby Mode It Drains 2-3% Of Battery In 1-2 Hour Even Everything turned Off And Also Stamina Mode Is Off.
5. Sometimes Wifi Stucked I Have To Reconnect It To Use.
6. Does The Phone Has IR-Blaster?
7.  And Most important - 4.2.2 Update When In India?
8 REPLIES 8
  1. Tempered glass, it should be as strong as Gorilla Glass
  2. if the pictures are a) stored on your SD card, you might have a slow/low class SD card (you should get a class 6 or higher)  or 2)  its an online album it will take some time to load
  3. X4 player as well as any other app, will be up to the developer to address this issue not Sony but it might be an slow SD card
  4. it will be wise to check what is draining your battery, but it seems normal
  5. elaborate on this issue
  6. it does
  7. you are not going to find an answer to that question, you have 2 options
  • wait for the update
  • manually update your phone
if you don't want to wait
How to manually update, downgrade, root 2013 Xperias
http://talk.sonymobile.com/thread/124152
GuptaPriyank
Well, as for your battery, try turning ON the Stamina mode, and see if it helps.
And for IR-Blaster, ZR does NOT have that feature. There is no IR port on my Xperia ZR.
Never faced an issue with WIFi, although connection strength gets down occassionally.
Karan_Yaduvansh
1. Should Be Or It Is?
2. I am talking about pictures clicked  By SAM.
3. If I Am Correct Then Its Developed By Sony And Also My All Video's Is In Internal Storage Btw Its Nt Imp For Me.
4. Nothing Is Showing In Power Management About draining.
5. Signal Drop Problem
6. Where It Is And How To Use It?
7.I Will Wait For Official Update.Any Idea When Its Coming?
Karan_Yaduvansh
Stamina Mode Is Always On In Ma Phone
Uliwooly Said The Phone Have IR Blaster?
What About Update DOes Your Phone Got 4.2.2?
GuptaPriyank
ZR does NOT have IR Blaster.
No 4.2 update for Xperia ZR in India as yet. Don't know how much more time will it take...
Karan_Yaduvansh
There Are Lot Of Rumors Among Its Water Resistance Have You Tried Putting It In Water And Does The Phone Comes With Preinstalled Screen Protector(scratch Guard)?
seamon
I put my xperia zr in a bucket of water with the camera led light on. It is working fine, no problems. THe shopkeeper gave me a free screenguard.
