HI guys im having a trouble with my throw notification on my xperia zl
It keep on appearing even when i have already force stopped it
I've tried to restart my phone but it appeared again
Anybody have a solution for me?
Is it appearing when you are performing any particular function?
No it keep appearing without any particular reason
go to
settings > xperia > throw settings > uncheck device notification
Wow that worked thank you edison
have the same problem.
But:
Under Throw settings there is only one checkbox, saying "Auto-select wireless option". I did uncheck it, but the Throw still comes up and prevents connection with SBH80!!
What shall I do to disable Throw??
same on Xperia Z Ultra.
I need to restart bluetooth headset, restart bluetooth on the phone, restart the phone. I can listen music and make few calls. After headset off and i am getting call on the skype. I am trying to on headset and answer, but there is no sound. I noticed that i now have notification appears. that throw trying to connect to my device. If i open it it will offer me to connect. And then i choose my headset it say Could not connect to selected device. If it get connected there is no sound on walkman player or calls. Alternatively throw report it connected, but walkman keep playing on internal speaker.
Maybe phone was affected by skype update. Right now i am thinking if it is possible to disable "throw", delete some files. Samsung just works and we have this terrible throw
we don't need it for just headset.
Just found this thread:
http://forum.xda-developers.com/xperia-z1/help/how-to-totally-disable-throw-causes-t2860830/post5510...
Searching way to to remove this file and see if it help.
I have this on an xperia v. I don't know how to find the .priv-app ... file. Is there any other solution to this problem now that it has been more than a year. In my case, Throw keeps interrupting the bluetooth connection to bluetooth speaker (same for two different brands) and then reconnects 15 seconds or so later. "Auto-select wireless option" is unchecked. Thanks for any help.
