xperia z5 camera issues
faregon
Today, when I woke up I had the weirdest thing happen, when I woke up and check my phone everything was going ok. I talked on skype and tried to turn on my camera and then the s*** hit the fan. First skype started crashing and I though classic skype but then I tried checking my camera and it just showed "Unfortuenalty camera stopped". I tried stoping it, clearing the data and then restarting the phone - didn't work. I tried PCC software reinstall. Tried jsut factory reset. Also unmounted my SD card turned off the phone removed the SD and then turned it back on. After all this and another PCC sofware reinstall+ factory data reset it worked for couple of minutes, and then it stopped.
I kinda gave up after few hours of battling with it and decided I'll go to my network provider since I have my insuranace with them.So I just restored my phone from a backup I did before all the reinstalls and factory resets. Now it's been charged to 100% almost and camera started working again kind of. My back camera works like before more or less but the front camera takes extra long to load and sometimes there's sometype of display stuttering. Any idea what might be the cause of all this ? Should I still bring it for check up ?
P.s. Sorry for the long post I hope all the important information is included.
P.s.s. Front camera still not working, it has its moments but its mostly not working and it gets distorted view if I shake phone, stops working eventually.
@faregon
You should take it to your Local support to get it inspected
