so my xperia z3 had gotten a little dirty and i took it to my bathroom to wash it in the sinc, all the flaps was closed. i washed it with not too fast beam of water. when it was clean, i dried it with a towel and put it into my pocket, when i took it up it was dead. I turned it on and it worked fine, but when i turned of the screen it turned back on again. so i rebooted it and it wouldn't turn back on again, it vibrated alot for about 5 minutes. i put it in a bag of rice for 12 hours then i noticed there was moisture inside the front camera. when i plugged it into the charger it blinks red light. none of the water indicators under the flaps have turned red so i guess water have found another way in? anyone got a solution? please help
Contact your nearest Sony customer care center and request a vacuum test. By the way, did you use soap with water to clean it?
Make sure to request a vacuum test.
