Try performing a system repair using Pc Companion as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
Sorry it's taken a while to get back, but just back from work. The phone is already off. When I start PC companion and connect the phone, the phone doesn't get picked up by the PC. I think this is because it just isn't responding at all, even when I press the small yellow reset button. Not sure if I'm missing something?
Connect the phone to a wall charger > press and hold Power & volume up for 10 seconds >let it charge for 2 to 3 hours
OK, have done that. The phone didn't do anything, but have left it plugged in and will see what happens in a few hours.
Keep us updated, if that doesn't work then contact your local Xperia Care
Hi, i have the same problem after update to android 6.01 - update was ok, but after I selected restert the phone, phone shutdown and wont to turn on!
