Xperia z3 Compact shutter problem
Hello!
I just had my phone return from being repaired, due to an issue on the back cover, to discover that the camera button is not working. This is what I have tried so far:
- Activate smart start on the camera options - nothing happens
- Clear cache, stopp/resume the camera app, restarting the phone- nothing happens
- Doing a factory reset- the same
Is there anyone who has a similar problem?
Is there something else to do other than send it again to repair?
Can this be related to software (my version 5.1.1)?
Thanks a lot,
Pedro
6 REPLIES 6
@ordepcosta
Boot on safe mode
if not, then repair the phone with PCC
PC Companion (PCC)
Bridge (for Mac)
if not then contact your Local support to get it inspected again
profile.country.US.title
Qatrium
Go to Settings -> About phone -> Diagnostics -> Test -> perform a "Camera button" test
Hey Uliwooly, thanks for the advice. Unfortunately it does not work... Next thing will be sending it to the local support. Hopefully it will not impair other faculties of the smartphone... Thanks
Dear Quester,
the same for your advice. I tried it and as nothing happened it gave a report that the test was failed.
Thks
@ordepcosta
Sorry to hear that, keep us updated.
John-BR
Hi ordepcosta
Welcome to the community
Here's how to run the repair on PC Companion:
  2. Phone Software Update.
  3. Start.
  4. Repair Phone
  5. Continue
  6. Accept data removal
  7. Next
  8. Wait for prepare
  9. Select Phone
And Bridge for Mac:
  2. On the Main Window select "Xperia > Repair Xperia Device".
  3. Ensure the phone is charged and select "Ok" in the following window.
  5. Wait until the initialising step is finished the continue as below.
  1. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
You will want to start these processes with the phone powered off and disconnected from the PC.
