Hey Guys,
Wifi doesn't turn On,even after several restarts but my bluetooth and mobile data works well, any one experiencing this issue, pls let me know the fix for this issue. it's quite annoying....
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
If the above fails then I'm sorry to hear this but you would need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
