Xperia Z2 notifications volume and incoming call are too low
Wishy
I just bought the xperia z2
and i'm facing a horrible thing here
the volume of the incoming notifications and the incoming call are too low
but when it comes to music via walkman its super
i've tried almost everything
1- clearing the data of smart connect
2- clearing the data of enhancment sounds
3- raising the sound volume and checking the X-Loud
even i changed the notification tone and the ring tone to anyother thing and it also didn't work
i noticed that the lower speaker only used when it comes to notifications and incoming calls
so is there any solutions or ideas!!
12 REPLIES 12
Thommo
Genius
Have you checked the volume levels for notifications in Settings, Sound then Volumes
Wishy
yes i did 😕
Tags (1)
Thanathos
have you found any solution...help me...please...i have the same problem....only mine is bigger...is very annoing the volume of incoming calls......i made an update at 4.4.4 and some settings in the enhancements settings are gone.....for example Xloud....how can i make my phone sound louder at incoming calls....help me...please !!!!
Demon1521
Turn On in audio settings ClearAudio+, it includes old XLoud. But anyway it wont be so loud like before 4.4.4 update.
Wishy
The Problem was not solved on Android 4.4.4 and yes Xloud is gone and the sound still low!
and it's driving me crazy!
Wishy
this solution doesn't solve anything! actually it makes the sound seems to be so bad and of course not clear
Evero
Please Sony, fix this issue. Phone is usted to be located and this prevent it
dandy63
Leader
As you have worked out....since the 4.4.4 update the notification volumes are definetly a lot lower.....xloud is incorporated in clearaudio+ .......this in my opinion is the root of the problem, i have tried various things & have actually 'unticked' clearaudio+ as i too felt it made things slightly 'muffled'.....
So for the time being until there is a 'fix' or Lollipop rolls out to the devices there seems to be no way round it......i am fairly sure that Sony are aware of this so hopefully it will be getting looked at :smileysmileywink:
M0ises
Yes it sounds lower than my old Xperia L...please Sony fix this issue.
It seems its not using speakers correctly.
