Xperia Z2 Build number 17.1.1.A.0.402 messing up
Msimbwa
Hi Colleagues
I have recently updated my Xperia Z2 with a new software build number 17.1.1.A.0.402 as my phone preempted me to do so, but unfortuanately after the update, most of the time my phone is misbehaving, like giving messages such as process com.android.phone has stopped, or contact has stopped or even sometimes when there is an incoming call aftershort while it leaves only notification light to indicate the incoming calls but you can not pick that call. This is annoying and giving me difficult time. Any help please. Thank you
2 REPLIES 2
Thommo
Genius
The only thing you can do is to perform a system repair and see if that fixes the issue
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down - This should start the repair or reformat process
HussainQuadri
Or you could try making a backup in backup and restore app, then factory reset the device.
Then restore the backup.
