Xperia Z2 blinking when USB charging
aldrifto
My Z2 was charging perfect until I connected the magnet charger, then it only charges with the magnet cable.
If I connect it via USB, then starts blinking and the "charging" signal comes on... off... on... off... etc... etc... but with magnet it charges problem free
I don't have the latest update because pc companion says that my phone is already up to date, maybe my country is the problem)
Any ideas of what that would be?
How could I fix it without loosing warranty and without taking it to repair?
Thanks
5 REPLIES 5
aldrifto
This is basically what's going on
http://youtu.be/_IH8O7X-llo
dm841
seems to me the usb port is loose on your device hence why its blinking when it contacts and off when it looses contact keep charging with the dock for the time been til you can get it to repair
Pelsebal
Hello aldrifto,
I have exactly the same issue with my phone.
It only charge with magnetic cable:smileyworried:
Impossible to charge with usb wether it be plugged on my pc or on electrical outlet. I've tried different chargers and different cables, nothing works.
james-russ
@Pelsebal wrote:
Hello aldrifto,
I have the same problem
Bandolero
I experience the same problem with magnetic charger that i bought for my z1 and now to charge my z2. Is abit loosen when you connect and sometime you move it a little it disconnect.
But i leave it on the table to charge it was all good.
If you guy tried with different charger and USB cable still the same, suggest you to bring the phone and charger to the local service centre for the tech to check it out for ya.
