Xperia Z1 Water Test
WhatDesign
Xperia Z1 Water Test  Thank you for watching.
2 REPLIES 2
broko
This is not a water test by any means.
It's a bad quality clip of two kids applying a ton of soap over a Z1, and then putting it under a strong flow of tapwater at first, then a weaker flow later. At the end of the video the most important part is almost completely cut out as there is no way to see if the phone took any damage or not. Overall, this is the most pointless video I have seen for a while.
PS. I don't think anyone should try this. Please, if Sony have ever advertised that you can apply soap to your phone and then wash it under a strong flow of tapwater - show me where.
rency_07_22
On a serious note, we should have the Water Proof test on the Service Menu. And currently, it says "Device does not support the function"... Tested it on water-resistant and waterproof devices from Xperia Go, Acro S, V, Z, ZR, Z Ultra and Z1, and sadly, Xperia Go has only this function working.
so when will Sony incorporate it on our device, and as you market Z1, the waterproof cameraphone?
