Xperia z1 screen replacement
Bekim
Will my xperia lose its waterproofness if i replace its screen? Please respond
2 REPLIES 2
Thommo
Genius
It may and may not - Depends on method used and whether or not you have a vacuum test carried out to test the seal once repaired but if done through a service centre then as standard a test is carried out
Jake-SonyXperia
Hi Bekim,
Welcome to the community.
I suggest that  you contact Sony Mobile within your region, they will be able to supply a service agent who could perform a vacuum test on the device for you, as well as perform any repairs.
Use my signature to get the details needed.
