Xperia Z1 not working after Lollipop update
Anira
HI,
Well i got notification for Lollipop update & started with the updation. Since then my phone got switched off & has not started yet.
Its only showing blank black screen with network & wifi bars, time, battery life icons. The touch has stopped working, The only button working is
of switch off or restart. For these I am able to select with the touch, which means the touch is working but due to update the phone is jammed.
Kindly help Its a new Xperia Z1, which I have bought just a month back.:smileyconfused::smileysad:
15 REPLIES 15
Press and hold power & volume up for 10 seconds > connect it to a wall charger > let it charge for 2 hours then repair it with PCC
PC Companion (PCC)
Bridge (for Mac)
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
Anira
The battery is 55% & i have connected for charging. Will loose my phone data by any chance?
_alexdon_
Data on the device is lost,data on microSD is not.
alexdon
Anira
Thanks for help I will try this. But I am really not happy with my phone data loss. In this case I was happy with the previous version only.:smileysad:
Anyways thanks for the guidance.
_alexdon_
You can also try to downgrade without data loss.
alexdon
Anira
How?? I charged upto 60%. What should i do now?
varun_maheshwar
Please Help.
I am also running into same situation.
I only see network bars, battery percentage and time on status bar. And nothing else. No touch, no display, only black screen. Power button seem to be working.
I tried connecting PCC, but it says that either input the SIM, or PIN, or make the device unlocked. I am sure its unlocked. If I press power button multiple times quickly, I see screen flashes showing that its at language selection page, but then it goes blank. PCC not working. Recovery mode also not working. I cant get to recovery mode using Power button and Vol up/down to factory reset the phone.
What can I do?
