I realise that there are a few threads similar to this; but not quite the same :-).
I am having problems sending texts from my Z1, it seems happy to send until the message runs over '1 message' in length, then it just says 'cannot send message'. Using the 'Resend message' option usually results in the last part of the message being delivered, but not the first.
Is there a setting for this that I am missing?
Thanks,
Simon
Try settings-apps-all-messages,clear data and force stop.Backup all your messages before.
Thank you for the suggestion alexdon, but I don't think it has helped :-(.
Hi Simbad,
In regards the SMS issue, this can be a limitation based on the network carrier. I first suggest contacting them to clarify if they have enable any restrictions.
If this does not help the issue, then I suggest that you try another SIM card, if another SIM card works then the issue is related to your SIM and will need to be replaced.
Let me know how this goes for you.
