Xperia Z1 acting strange when running NAVIGON
Penge58
Hello all
I have a Xperia Z1.
And I have installed Navigon.
Everytime I start Navigon it disconnect WLAN and I need to go to Setup and turn WLAN on.
And then when I exit NAVIGON the phone jumps into "Position Services"...(I am not sure that is the correct name because I am translating from Norwegian).
Thats the page were you can let Google see your position and so on.  All is set there so I don't know why it jumps into that screen when exit NAVIGON.
Anyone seem things like this before ?
Petter
2 REPLIES 2
Thommo
Genius
I use Copilot and don't have this issue however there is a similar setting to which you describe which is used for live traffic and need data switched on for use - So in my settings for the app I can switch this on or off - So if you have data switched on but your app setting has been set to switch it off on start up then that may be a cause for your issue - As for your other issue - I have denied Google the ability to set or see my location so again that page never pops up
Penge58
Thank you for your reply Thommo.
I think I have solved it.
I hope so.
I unistalled all apps that had to do with Navigon and installed only the Navigon Europe again.
Seems to work fine now.
I have a few other apps which I had installed earlier that was kinda add ons and I have not installed it now and it seems that it's working bette now.
Thank you anyway.
Petter
