the new update has improved a little bit the phone speed and UI stability, also improved the pictures and camera resolution,
can.t change the focus settings, when i try to change to multi autofocus the cam close and (unfortunately, camera has stopped) errore appeare.
any help
Turning the Stabilizer On results in more noisy images due to the software upping the ISO up to compensate for handshake movements by using a faster shutter speed. Higher ISO = more light sensitivity and can use faster shutter speed but introduces more noise.
With the camera app crashing, try to reboot the phone. Shame because its a previous problem I also encountered rarely on .534 firmware.
I have the same problem
Tried to reboot phone, but no use. Thought it was overheating, but it was -5 C outside, and when I got back home and tried again, it is the same old story.
@Rosen - Have you also tried clearing the Camera application: Main Menu > Settings > Apps > all > Camera > Clear data.
