Xperia Z water damaged - construction fault
zoon
Hello everyone,
In conclusion, my question is: If water enters my Xperia Z, but not through the ports, and destroys my phone. Is there anything I can do?
Here's the longer story to explain what happened and potentially warn people from ending up like me:
I have probably never taken better care of a phone as I did with my Xperia Z. I have owned it for about 9 months.
However I did never hesitate to let it get wet. I never submerged it in a pool or anything, but rain, a quick flush, etc. I never gave it a thought since it's a water proof phone and I always double check the ports are closed.
 - Since I use the desktop charger I rarely had to open the ports as well.
Anyway, the other day I took the phone with me into the shower because I was in a hurry to read some e-mails. Later that day I noticed there was water vapor under the camera glass. By discovering this, I immediately turned the phone off and threw it in a bucket of rice. Reading on these forums I learned I could see "where water entered" by the indicators that turn red. The USB port indicator had turned red, **bleep** it - I assumed it was my own fault not closing the port.
By my luck, after 4-5 days in the rice bucket I turned the phone back on and it was working (almost) flawlessly (the proximity sensor was acting a bit weird tho). By reading on these forums I was suggested to leave a little piece of water detection paper on top of the already red one, close all ports, triple check and then gave it a dip. No water entered any ports, I was happy.
 - Half an hour later the phone was acting all weird. I did not understand it until I saw water again under the camera glass, so water HAD entered but NOT through the ports!
At this point the lock/power button was not working. I wanted to turn off the phone, but I couldn't. Press and holding the button did a restart rather than showing me the menu on screen to turn off. Also, when the phone went into sleep mode, there was no waking it up by pressing the unlock/power button - doing a reset by holding the button would turn the screen back on, functioning, but once the screen goes dark it stays dark. I could use a second phone to call it, the screen would wake up and be functioning. Ok, so it just wouldn't be turned off, I threw it in a bucket of rice again and let it stay for a week.
Today I took the phone back out and it's still unusable by this behavior, so nothing changed after drying it out.
My phone barely has a scratch, I feel I have taken very good care of it and felt this was a quality product making me feel like a Sony fanboy. So I don't understand how and why this has happened.
What could I do now? If I was to pay my local phone repair shop to fix it; I wouldn't. It will be expensive and I still couldn't trust the phone to be water proof. Honestly, if this is a general fault Sony should admit it and replace the broken phone. I would be OK with keeping a replacement phone away from water, but I am quite disappointed with being left without a phone right now, since Sony warranty does not cover water damage???
Hampus
I'm sorry to hear that.
In this case, you would do best by contact your local support team for further information about how to proceed with this in the best possible way. They can provide you with information about the warranty and where to find the nearest service center so a technician can examine your phone:
