Xperia z is blocked and does not work when connecting headphones
jennic7
Hi I have a problem with my xperia Z. Three days ago I was using it , lock the phone and while I wanted to use it again, but the screen does not encendia for more you pressed the button is not unlocked . Let stand a few minutes and not served , followed not turn on the screen. Vibrated because messages arrived but as much as he pressed the unlock button did nothing . I did that restarting and still did not serve . I had to leave half an hour to try again and now if he returned to work. But since then every time I connect Helmets and block mobile, does not work for a long button press . They can get WhatsApp or whatever ignoring . To back up and running as it should , I have to disconnect helmets and wait a bit to give the button and function . That may be or I can do something ?
2 REPLIES 2
Thommo
Genius
If your phone turns on and the screen works then try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Thommo
Genius
If that fails then I'm sorry to say but you would need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
