xperia z camera slow lunch
TechNoRemix2K
Hi why it takes 3-4 or 5 sec for the camera to lunch on mine xperia z? And does all the xperia z are little bit laggy? Im little bit worried about my xperia Slightly_frowning_Face I see a lot of videos with camera test and it was like 1-2 sec or quicker for camera to lunch Slightly_frowning_Face Any ideas guys?
6 REPLIES 6
Aky1
Its a software bug.So you are not only the one having same problem. Hope they will fix it in next update.
PS: its launch not lunch(food)
Johan
Check if you might have many applications running in the background and try to close some of them and check again.
@Johan I've seen this issue since I got my Xperia Z, it doesn't matter if I have apps running or not, even quick launch from the lockscreen takes several seconds, it's not a "huge" issue, but it will be great if the camera launch as fast or faster than the Xperia S (less than a second). more over, if you switch from camera settings auto to scene etc it will take 1-2s to be able to use the camera.
GeoffH
Enthusiast
I think Sony has a choice here - either run the camera app on startup as part of the boot sequence or just remember to start the camera after boot - either way same result
I think what you'll find is that other manufacturers do this to prep the camera ready for fast starting - should Sony do this - well probably
andriykoua
I am having exact same issue on my Xperial ZL (C6506) (Bell Mobility - Canada) Android Version: 4.1.2, Build number 10.1.A.1.395
It takes more like 5 seconds to open up a camera. Nothing running on the background. I can't beleive that SONY didn't test this software prior to releasing it.
Antares19
I have same problem on Xperia Acro S. Camera starting lag is 5-3 seconds.
And that's MAJOR problem for me, because it makes phone camera useless in most cases I need it.
I use phone camera when I see something interesting... and while app is starting, thing I wanted to capture is already gone.
That happens all the time... pretty frustrating expetience Slightly_frowning_Face
What for there are all this dual core processors if they can't ensure such a simple thing as instant camera in the phone?
Huge usability fail )
I'm looking for the way I can solve that problem. Last two firmware updates changed nothing.
Is there a way to make camera app be always running as background process?
