After my xperia z's battery got totally Drained, i connected it to the charger for charging but its not charging neighter is it turning on. All it does is flashes a red light and SONY logo is displayed on the screen then it turns of and again does the same thing on a loop! How do i Fix it??
Hello my phones not even turning onto the sony sign i dont know what i can do help please
Connect to wall charger,force restart(power button+vol up until the phone vibrates).Let it charge for 1-2 hours.
Thank you, suyogpatil. but in my case, the battery was not fully drained! yet, unexpectedly, the phone was not getting switched on. But after I tried like you've mentione (power switch & volume up together) it started vibrating and now, thank God, there is some light on the screen. but it is not back to the normal main screen yet. what next should i do? the screen just shows a battry charging symbol in the centre of it, if i press the power key. the device is still in charging mode. what is next, to get the phone running normally? thanks in advance, by SJ
hello sj4. what happened next? my phone also vibrate
now what did you do next?
is your phone ok now
kindly reply
This is perfect. Mine died as I was texting and would not charge. I held the power and the volume up at the same time and it did the buzz and started charging right away. Thank you for that reset tip.
