I have an Xperia z which presents the following issue:
The battery indicator says the wrong values. This always happens
when the battery reaches less than 40%. Hang up the phone eg
with 37%, but when I connect it again, the indicator will show me around
50 to 60%. This happens whenever I turn off the phone and this has
battery percentages between 40% and 20%. In other percentages
the information presented is correct.
Is a bug?
Same happening to me. It started right after the last update. I didn't pay much attention however. So far it occurred two times.
With me was also after upgrading to latest version of software, and now the customer's solution is to take to a repair center, without saying if it's a bug of the last update or a hardware problem.
Well, if resetting the phone doesn't help, sending to service is the next alternative. Without examining the phone it's impossible to tell what have caused this issue.
