i have xperia x8 and im using it as a second phone...so it was on android 1.6 and it was working with no problems...i decided to do u factoryreset after that my wifi and bluetooth wont work anymore if i try to turn on wifi i get a bootloop,if i tried to turn on a bluetooth nothing happens....so i updated it to 2.1 still bug,i flashed 2.3.7(several roms)still not work,im not getting bootlops just it says unable to scan networks,and after that i cant turned off,bluetooth same problem....what should i do?i dont care about e bluetooth but sometimes i need a wifi..:/
Since you have tried to update the software and also using different custom ROM's and you still get this problem I suggest that you contact your local support team to check if you can have the phone examined and fixed at an repair center.
