My xperia x10 mini's display is going off, after draining battery & charging, display will come for 2-3 min, then again goes off.. plz help....:smileyconfused::smileycry:
Hi, did you try with another battery? Did you try repairing phone software?
Sony Update Service for software repair, http://www.sonymobile.com/gb/tools/update-service/.
Be aware that software repair will erase phone data completely, backup if necessary.
I have the same problem and the am not even able to get the Xperia to be repaired via PC Companion. I have not changed the battery or tried to repair my phone in any other way.
Please help
Hi bijo, see if you are able to find another battery to test. If not, suggest you send it to your local Service Centre.
