Folks,
Having an issue with Xperia Weather widget location automatic update. It just stays whatever I set manually before even selecting "use my current GPS location".It finds location OK, but should it follow then automatically or it works only in "manual mode" ?
GPS settings are activated OK.
On other weather app this feature works fine.
Anybody experiencing the same problem?
Thanks.
@sdub wrote:Folks,
On other weather app this feature works fine.Anybody experiencing the same problem?
Thanks.
are you in the UK? if so the MET weather widget is alot more better for GPS.
dont forget to give a Kudos
Hey
That "use my current GPS feature" is just to set the location. It doesn't works as automatic mode to update your location on it's own.
You will have to do it manually again if you wish to change the location.
