xperia V walkman bug solution please
Omar211
I have purchased the xperia v few days ago with the JB out of the box , well frankly the most application i use is the walkman music player and the other applications or functions work properly . the walkman doesn't play next tracks or take a delay about 4-5 seconds maybe beside after unplugging the earpieces the speaker doesn't work to . i have visited your fourms and i found it's a global problem with all xperia v users have the JB update and seems to solution has been suggested or made by any of sony officials (btw i have tried repairng the phone using your pc companion with no result ) please i want to know how to solve this problem becuase our local sony mobile agents here won't help .
Thanks
3 REPLIES 3
godinqc
You can look in the Xperia T forum, I believe there was a couple of workarounds given
ex:
http://talk.sonymobile.com/thread/108882?start=0&tstart=0
Also I believe that one of the note indicated that this will be fixed in an upcoming update
Thanks
Omar211
thanks godinqc for your help first the smart connect can't be uninstalled from my phone and i can't change the security pattern for now just be advised there is another bug in the standby mode the digital clock also stops and get back again once you click the power on for example assume the time is now 7:00 after 30 mins it should be 7:30 it appears 7:00 then instantly change to 7:30 anyway ill wait untill this new update realesed and thanks again for being intrested Slightly_smiling_Face
Rickard
This problem has been escalated and should be fixed in the next update.
Locking this thread as there's already several regarding this problem. Please use search before posting new threads.
