xperia v restarts while charging
zamaraii
for about 2 days i have problems with my phone while charging. when i insert the charging cable my phone restarts itself. does someone have this problem? it's a cable problem or with my phone? i will try with another cable to see if this happens...
2 REPLIES 2
Jake-SonyXperia
If a replacement cable does not work try performing a software repair, this will help clarify where the issue is located.
To repair the phone software
1.     Install PC Companion on a Windows PC from Support
2.     In PC Companion, under Support Zone and click Start.
3.     Under Phone Software Update, click Start.
4.     Click repair phone.
5.     Follow the on-screen instructions.
zamaraii
Thank you for your reply! The problem is rezolved after replacing the cable. It seems to be a loose connector. I'm happy again Slightly_smiling_Face
