Hi all,
Mine One year Old Xperia U problem switched off suddenly yesterday. When i tried restarting , phone boots but display goes blur with only transparent bar glowing.Each time when i press power key phone restarts and goes to same blur mode with glowing transparent bar.
Tried restarting the phones many times but no luck
Repaired phone using PC companion but still the same . Today morning i removed the SIM and phone worked like a charm. Thinking it might be Sim issue have inserted differnt Sim , but still same result.Without Sim, phone is working fine.
If any one of you have faced the similar issues please post. Would expect Sony developer to suggest the possible causes.
Same issue with my Xperia U
Same issue with my one and half yr old xperia U since today morning...
tried factory resetting, software update, software re-installation... all in vain.
Sony is cheating its customers
same problem here i took it to service center they said its a hardware problem and it costs 6k -7k rupees....
I am also facing the same issue.
If so many users are facing the same issue then it means it is the issue with the Xperia U model only.
Sony must compansate for the issue which we are facing.
facing the same issue........any solution???
HI
friends
when i insert my sim card in my xpiria u then it suddenly switch off and only led is running
and when i start my phon after this then also turn off ..............
plz help me in this problem.....
and when i start it without simcard, it running good
hi there i have the same problem, trying to search on search engine if other android phone facing same problem
GOOD NEWS A.K.A SOLUTION
First diagnosis your problem
-> Turn on your phone without Sim card, if it's work normal you can move to next step.
-> Turn on your airplane mode ON, Then turn off your phone
-> Insert your sim card and turn you phone on
-> Set your wifi on and keep airplane mode ON
-> If you can do step all above you can move to the solving step
=> The problem might accors as the result from "setting crash" between your phone internet setting and your sim setting.
we did hit "Internet setting" on ->Setting ->Xperia ->Internet settings didn't we
Second. The solution
-> With your phone still on and at airplane mode with wifi enabled, downloand "clean master" on google play.
-> Restart your phone without sim card, turn off airplane mode and wifi.
-> Clean your chace and free up some your rom a little.... close the app after you finished
-> Setting Reset your phone ->setting ->backup&reset ->setting reset [you will not lose your data and downloaded apps]
-> After the reset, turn off your phone to insert your sim card
-> Turn it on, and if it's working please smile and thanks god
_____________________________________
if you still have some problem try this one
turn your phone on without sim card, enable airplane mode. turn off you phone
insert your sim card to your phone and turn it on
turn off your airplane mode, this will make your phone to crash.
hold your power button to restart. if it's on then it's done
i'm just an unemployed poor you can "kickstarter" me by donating a little help to my Paypa at [email protected] .thanks for your kindness
