If you have internet and location enabled,you might be able to unlock it using:
- gmail - recover
- myxperia - if you change the PIN/password
- google device manager
If the above is not helping,you have to perform a software repair.
Sorry to say but but your only option it to perform a system repair which will erase all data unless it's on a SD card then you would want to remove this 1st, It is for security reasons that that this happens, To perform a system repair follow the below guide
Performing a system repair using PC Companion as this will factory reset your phone
