Hi, my Xperia U has a problem on multitouch.
When I touch with 2 or more fingers, only the first finger will work.
The strange thing is that it seems that the Xperia U recognizes four fingers but only one works.
I can't zoom in on images, can't play dead trigger, because I can't walk and aim in the same time...
There are nothing to do now?
I'm sorry, I'm out of ideas
What is the firmware more updated? to flash on flashtool.
It is possible that the screen has been misplaced? because I was several months without using the phone because the touch was in trouble, and now changed and it is with this problem ...
You left quite a bit of info out, your phone was:
rooted
the digitizer was damaged
that could be the reason, perhaps the digitizer wasn't installed correctly, maybe a ribbon its loose
What is the problem in root with multitouch?
typo, I meant to say, bootloader unlocked, but I'm out of suggestions, perhaps you should contact your local Sony repair center
