My xperia tx has had blank screen issue since yesterday. It happened after I unlocked the screen. Everything else on the phone is working, backlight, touch panel are all working. The screen itself is blank no matter what I do. Even chargin the phone while it's off will not make the display to show anything; only the backlight is on. I can get snapshot using screencap via adb and snapshots look all normal. The phone has the latest stock rom, no root, locked bootloader. I wonder what could happened to my phone? Has sony been aware of the issue? Thanks!
remove the battery > press and hold the power button for 5 seconds or so > place the battery back on and check again
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
Thanks for the reply. Unfortunately, it doesn't help. The screen is still blank.
repair it with SUS
Update Service (SUS)
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
Thanks for the reply. But I think it's a hardware issue. Because even the boot animation or charging indicator is not showing up. I have found another user who has the same issue, and all software based fixes don't work
if that's the issue then you should return it asap
