Xperia TX Battery Problem - Using 2 Original Battery
darkslasher47
Hi guys, I just want to share with you a problem I encountered using 2 original Sony Battery BA900. I have 2 batteries, both original. Both of them fully charged, 1 battery inserted into my phone and 1 as back-up. After my battery discharged up to 10, 20 or 30%, I will try to change to my back up battery. After changing it, the phone dispalys the same battery charge level with my first one, for example before I removed the first battery, the charge level is 10%, changing into a new one that is fully charged to 100%,it will also show 10%. The battery will continue to drain up to 1% and will stay there for several hours. So that means, the battery is really fully charged but the battery icon shows a wrong level.
However using another local battery (not original from Sony), I will not encounter this problem, meaning after the original battery drained up to 10%, I will change to a locally made battery that is fully charged, it will show 100% on the battery level.
Note that any ROM that I use, Stock or Custom ROMS available for TX, I will encounter the same problem using 2 original batteries.
Is there anybody who encountered the same problem with me? Any suggestions to fix this?
Johan
I have never heard of this before. Could you please let me know if this problem remains after reinstalling the phone software using SUS?
If it does this will have to be checked at an repair center. In that case contact your local support team.
